TwinTurbo.NET: Nissan 300ZX forum - Shop manual works...bad temp sensor per ohm check
Subject Shop manual works...bad temp sensor per ohm check
Posted by ricktek on May 31, 2013 at 11:15 AM
  This message has been viewed 350 times.
In Reply To Auto transmission temp sensor....need to replace? posted by ricktek on May 31, 2013 at 08:46 AM
Message Ran through check of all contacts and fuses...everything passed until the resistance across the temp sensor on the harness. If past posts are correct - this failure causes bad shifting (or no shifting) from 3rd to OD....I will verify and report back for future troubleshooters.
Any advice would be appreciated - never changed this sensor out before...but it sounds pretty easy.
